TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
2010 Z-71 Lift and tire combo??????
Old Oct 13, 2010 | 08:58 PM
LSXS10's Avatar
Default 2010 Z-71 Lift and tire combo??????
Here is the deal guys, Im getting differnt info on tire size for a 2010 z-71 with a 2" leveling kit. I plan to keep the factory 18" wheels and i have been told i can run a 285-65-18 with no rub issues., and also could run a 305-65-18 and trim the bottom of the inner fender? Any info would be a great help and if you have a pic of a 2010 with the factory 18" wheels and a 285/305 tire with the 2" lift it would be great. Thanks, Heath...
Old Oct 13, 2010 | 09:29 PM
sleepersilverado's Avatar
FWIW i have factory 20's but i have ran 33's no issues with a leveling kit and now 35's with a little clearancing on a 3"lift. Lots of haters said neither could be done also.
Old Oct 25, 2010 | 10:28 AM
blackjack325's Avatar
sure, but after your suspension starts flexing?? lot of tire scraping, i imagine...
Old Oct 25, 2010 | 11:13 AM
beastmode's Avatar
Import Moderator
plus if its the 3" rough country kit... chances are his alignment is off, his coils are rubbing and his truck rides like crap, because the 3" RCX kit is a total piece of ****.
if you want a little bit of rake with a smooth ride get yourself a Top Gun Customz 2.5" leveling kit and a set of NBS (99-06) blocks/ubolts. That is what I am running minus the NBS blocks (I like mine level) and I scrubbed a tiny bit backing in my driveway with 295/55/20s until I trimmed about an 1" on the front and back of my front wheel liners, now its fine. My truck still feels stock too but I just ordered a 5" RCX kit the other day
Old Oct 25, 2010 | 12:01 PM
tanz45's Avatar
Stuffage = FAIL
Go with the 33. (285)
Old Oct 25, 2010 | 12:51 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Originally Posted by tanz45
Stuffage = FAIL
you mean 32 285s are 32.75 tall iirc 305s are a true 33. and FTW i dont like stuffed trucks either
Old Oct 25, 2010 | 12:52 PM
Kerr's Avatar
narrow it down to the brand of tire you want.. then go on there web page and compair the actual size... sometimes depending on brand the over all height is not as far off as it sounds..
say a 285-60-18 is a 33.5 and a 315-60-18 is 34. inches..
Old Oct 25, 2010 | 01:47 PM
tanz45's Avatar
Meh..
I was just quick comparing, I just run 16's. And yeas, brand matters.
285/75/16 = 33x11.5
305/70/16 = 33x12.5
315/75/16 = 35's
So for tire calcs above a 16'' rim, I fail.
Old Oct 25, 2010 | 06:05 PM
LSXS10's Avatar
Im leaning toward the nitto trail grapplers in a 285-65-18 on the stock LT alum. wheels. As far as the lift it will be a rough country 2" leveling kit on the front and stock on the rear. I drive the truck 70-80 miles round trip to work and its just not feasable to go any bigger with it. This setup is suppose to work with NO rubbing. Please tell me if im wrong or if i can a tad bigger tire.......Thanks for all the help.....
Old Oct 25, 2010 | 06:19 PM
beastmode's Avatar
Import Moderator
Ur tire on stock 18s - 285/65/18 = 32.83"x11.93"
My tire on stock 20s - 295/55/20 = 32.91"x12.52"
As I said.. mine rubbed a tad at first with the 2.5" TGC kit. I would imagine you should be fine with the RCX 2" and a tiny bit of trimming of the inner fender liners
