TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
1500hd leveling keys?
Old Feb 23, 2006 | 09:49 AM
02sierraz71_5.3's Avatar
Default 1500hd leveling keys?
Whats out there to level the bigger trucks?
Old Feb 24, 2006 | 02:29 AM
NoChrome's Avatar
you can use stock 1500 (non HD) keys to level it out, or just crank the **** out of the stock ones, it was good enough for me to run 33's.
This one is photoshopped (MS Paint) but my tbars have about 4 turns on them here, this is before the 33's and there not maxed out either.
Old Feb 24, 2006 | 11:49 AM
Have you used the ford keys on the HD trucks?
Old Feb 24, 2006 | 11:57 AM
samdogmx's Avatar
8 Second Club
you only use the ford keys on the 1/2 ton trucks, You (HD trucks) need the GM green keys, witch are the stock keys from the 1/2 ton trucks.
Old Feb 24, 2006 | 12:28 PM
nochrome is saying he used the stock 1500 keys on an HD?
Old Feb 24, 2006 | 01:37 PM
NoChrome's Avatar
No i didnt use anything, thats stock with some adjustment.
The keys are indexed. Meaning they have a Hex pattern inside the key, and the how the hex pattern is cast into the keys determines the index.
2500/1500HD have the LEAST indexing
1500's have a moderate amount
f150's have the most extream mount of indexing.
Ford keys will not fit our trucks because of the preload required to install them is just too much.
Old Feb 24, 2006 | 03:30 PM
samdogmx's Avatar
8 Second Club
yeah so if you want to level out an HD you need to use the 1500 keys.
Old Feb 24, 2006 | 03:42 PM
NoChrome's Avatar
Here you go, 33's with stock keys maxed out.
Old Feb 24, 2006 | 04:52 PM
Ok so the green keys are the stock 1500 indexed keys and they will level a 1500HD?
Old Feb 24, 2006 | 04:56 PM
NoChrome's Avatar
Yes..
