TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
What is the best tool for cutting braided stainless hose???
Old Mar 7, 2012 | 06:07 PM
BlackGMC's Avatar
Resident Retard
Default What is the best tool for cutting braided stainless hose???
I am just wondering what you guys use to cut braided stainless hose? When i did my tranny lines i used black electrical tape and a cut-off wheel. It worked ok. I was wondering if i used a big bolt cutter with the electrical tape would work decently.
Old Mar 7, 2012 | 06:15 PM
RibeiroBJJ's Avatar
Praise The Lowered
Electric Die grinder @ 26,500 rpm with 3M Green Corps cut off wheel 1/32"..Of course wrapped in the tape of your choice..
Old Mar 7, 2012 | 06:23 PM
sharpshooter's Avatar
Chisel- check YouTube videos
Old Mar 7, 2012 | 06:35 PM
skolman91's Avatar
x2 really sharp chisel, i watched them before i tried and figured a cutoff wheel would be better. but like u said it just worked ok, where as two whacks with elec tape and a really sharp chisel left a much cleaner cut and was easier..
Old Mar 7, 2012 | 06:45 PM
BlackGMC's Avatar
Resident Retard
I just watched a youtube video and the guy used a cable cutter like the one below and it cut through it like butter
28" Cable Cutters
Old Mar 7, 2012 | 07:25 PM
AndysC3's Avatar
I used a bow saw with a 42t blade. worked out great.
Old Mar 7, 2012 | 07:27 PM
charcold-bowtie's Avatar
Electric tape and a cut off saw is what Ive always used.
Old Mar 7, 2012 | 07:48 PM
smokeshow's Avatar
Mod with training wheels
Chop saw. Basically anything with high blade speed. If it frays the braid or crushes the line, it's going to be a pain in the *** to slide into the fittings. And you will need electrical tape to help prevent fraying. Also, the Russell brand AN fittings are a bit easier to work with than the Earl's for getting the line into the fitting.
Old Mar 7, 2012 | 08:58 PM
sureshot's Avatar
I used the sharpened chisel method. It worked great with no frays.
Old Mar 7, 2012 | 09:03 PM
gasmachine85's Avatar
Chisel and a large hammer on and alum plate. if you cant cut it one whack it is the cleanest cut ive tried.
