TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Tig fab pics! (Self taught)
Old Feb 20, 2014 | 06:32 AM
  #31
dirt track racer 81's Avatar
Yea I really wanted the syncrowave 210 but it was just too much
Old Feb 20, 2014 | 11:34 AM
  #32
lsxperformance's Avatar
Ya it was a tough purchase for me at first too. I had to keep asking myself is it neccary do I really need it? I'm happy I did it tho thought my self a skill that had always fascinated me. Just hang in there till you get the hang of it. My suggestion before you leave the welding store is buy a gas lense, and matching cup, and also e3 tungstens you sharpen to a point and you can do stainless, moly, aluminum, mild steel... Pretty much everything. When I started out I had to switch back and fourth between and spent a ton of money doin so. The e3 cost the same as the ones your supposed to use with aluminum anyhow.
Old Feb 20, 2014 | 11:37 AM
  #33
Also the filler I use is 1/16 on thin aluminum .080wall. It's too hard to kohen the alloy your dealing with so get a nice all purpose filler to practice with..
Old Mar 7, 2014 | 01:22 AM
  #34
Here's a couple more pics of the giant fab project, made some catch cans and a vent tank, then a dry sump oiling system for turbo not sure if you can see everything. I supported my local ceramic/ powder coat friend well on this set up.
Old Mar 7, 2014 | 01:34 AM
  #35
And here is the big picture, the good pic won't upload. Sooo I did a quick vid of the underside.
http://youtu.be/NfSCszCFfXM
Old Mar 7, 2014 | 05:39 AM
  #36
I'll get some more pics tonight..
Old Apr 4, 2014 | 01:49 PM
  #37
sprayed99's Avatar
Here is some bullshit from the shop.
Miller Dynasty 350
Lincoln Square wave 175
Old Apr 4, 2014 | 03:25 PM
  #38
sprayed99's Avatar
5356?
Just an FYI anything that meant to handle any type of heat like coolant tanks or radiators or oil tanks needs to be welded with 4043. 5356 has a tendency to crack when used in higher heat applications.
Old Apr 4, 2014 | 05:37 PM
  #39
Blackpanther99's Avatar
Miller Dynasty 350
v
Great stuff!
Old Apr 4, 2014 | 07:59 PM
  #40
sprayed99's Avatar
Here is a coolant surge tank we built for the 99-07 trucks.
