TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Plasma on the cheap: LCON to LG40 consumable mod
Old Mar 13, 2016 | 01:43 PM
xEtherealx's Avatar
Default Plasma on the cheap: LCON to LG40 consumable mod
I just modded my plasma cutter to accept the cheap LG40 consumables instead of the very expensive LCON consumables, and it's super easy. My plasma cutter was relatively very cheap but after running out of consumables I found that this wasn't really the case...
The plasma cutter I chose is the Lotos LT5000D, and you can pick it up for around $300 on amazon.
<a href="http://www.amazon.com/gp/product/B004VFJL14/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creat iveASIN=B004VFJL14&linkCode=as2&tag=russebrenn-20&linkId=N2HIN7F4NO6CHBOV">LT5000D Lotos LT5000D 50A Air Inverter Plasma Cutter Dual Voltage 110/220VAC 1/2" clean Cut</a><img src="http://ir-na.amazon-adsystem.com/e/ir?t=russebrenn-20&l=as2&o=1&a=B004VFJL14" width="1" height="1" border="0" alt="" style="border:none !important; margin:0px !important;" />
The consumables I'll be using are super cheap ($20 for 85pcs) and made for other torches. You can find these at
<a href="http://www.amazon.com/gp/product/B015TI7UQE/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creat iveASIN=B015TI7UQE&linkCode=as2&tag=russebrenn-20&linkId=QLICMJQJJJXBUCBO">GENSSI 85pcs PT-31 LG40 Air Plasma Cutter Torch Consumables Kit 30/40A CUT-40/50 CT312</a><img src="http://ir-na.amazon-adsystem.com/e/ir?t=russebrenn-20&l=as2&o=1&a=B015TI7UQE" width="1" height="1" border="0" alt="" style="border:none !important; margin:0px !important;" />
Just for comparison, the LCON consumables are $105 for the same quantity.
<a href="http://www.amazon.com/gp/product/B004V46NAW/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creat iveASIN=B004V46NAW&linkCode=as2&tag=russebrenn-20&linkId=4AHO75WL2SK2SVSA">LCON90 90 pcs Lotos Plasma Cutter Consumables Nozzle Electrode Cup and Ring for 50A Lotos Plasma Cutters Cut50D, LT5000D, CT520D, BLCT520D</a><img src="http://ir-na.amazon-adsystem.com/e/ir?t=russebrenn-20&l=as2&o=1&a=B004V46NAW" width="1" height="1" border="0" alt="" style="border:none !important; margin:0px !important;" />
All you need to do is drill out the torch to 5/16", to the existing shelf depth. The LG40 electrodes will then slide right in, and the LG40 caps are slightly shorter which will make the entire assembly fit perfectly. You must use the electrode, tip, swirl ring, and cap from the LG40 assembly.
Attached Thumbnails Plasma on the cheap: LCON to LG40 consumable mod-img_20160312_204213.jpg   Plasma on the cheap: LCON to LG40 consumable mod-img_20160312_204825.jpg   Plasma on the cheap: LCON to LG40 consumable mod-img_20160312_204939.jpg
SloStepSide
Apr 2, 2016 04:20 PM
CanadianVRss
Mar 14, 2016 05:29 PM
droppedchev
Mar 14, 2016 05:42 AM
erniedogg1
Mar 9, 2016 07:57 AM
05RST2NV
Mar 6, 2016 10:45 PM
