TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Laser Alignment Tool (accsy pulleys)
Old Nov 7, 2012 | 10:38 AM
BigKID's Avatar
Default Laser Alignment Tool (accsy pulleys)
Has anyone here tried to make their own laser alignment tool to find a misaligned pulley? Since doing the 8-rib swap, I have a squeak/chirp that comes up after a new belt has worn in a few hundred miles. I am not totally opposed to buying the DriveAlign tool but $100+ for a tool I will use once doesn't seem practical to me. I have a few of the cheap laser pointers here and was thinking of affixing one to a section of old serpentine belt with an elastic cord to hold it to the pulley. Where I am stuck is how to get the pointer perfectly centered and attached to the section of belt? Without the laser being perfectly parallel to the belt I don't see how it would be any better than the straight edge I am using. Thoughts?
Old Nov 7, 2012 | 08:23 PM
silver-mod-o's Avatar
Hunt&Fisherator
I've always used a piece of bright twine in the outermost rib. Determine a known good plane, usually on the crank pulley and check pulley to pulley based on that. Besides that, I've always used the laser tool.
Vortec350ss
Jan 12, 2016 10:36 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
