TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Getting dents out of pipe.
Old Aug 7, 2012 | 02:58 PM
wheeliE-maxx's Avatar
Default Getting dents out of pipe.
My driveshaft left three of these beauties behind as it made it's departure. Probably no power hit, but it seems to sound a bit different. Might just be my imagination. I could cut the pipe down, cap the ends, and freeze water in it like you would a two stroke expansion chamber. Weld it back together later in my fabrication class. I don't think pulling on an attached stick welding rod would work (Herculean force required). Any other ideas on what I could do?
Old Aug 7, 2012 | 04:22 PM
colekill's Avatar
KickinAssAndTakinNames
maybe rig up some sort of slide hammer. tack a long welding rod on with a sliding weight(the head of a hammer without the handle) and some sort of plate on the end that when struck would Pull up on the dent.
Old Aug 7, 2012 | 04:41 PM
outlawz2004's Avatar
a slide hammer and a torch to get it hot would probably work.
Old Aug 7, 2012 | 04:44 PM
TXsilverado's Avatar
cut out a 3" section and weld in a new piece of pipe.
Old Aug 7, 2012 | 05:21 PM
Thanks for the help guys.
Old Aug 7, 2012 | 05:33 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The dent fix type stud guns work well.
Old Oct 16, 2012 | 08:19 PM
TG02Z71's Avatar
Maybe try the heat and cold air trick thing?? it maybe will pop out. like body shop guys have done.
Old Oct 16, 2012 | 08:25 PM
Mangled03gmc's Avatar
Baltimore Whore
Im with TX, cut it out, weld new metal in, or the torch, slide hammer should work fine also
Old Oct 16, 2012 | 08:37 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Is that a Cal Speed tailpipe?
Old Oct 16, 2012 | 08:46 PM
Baltimore Whore
wait for it.........wait for it......... BAM
