Texas We've Seceded from the Union
WTT: Built T/A for 03+ Silverado\Sierra
Old May 17, 2009 | 08:02 PM
Powerhouse's Avatar
Default WTT: Built T/A for 03+ Silverado\Sierra
My mods are:
New GM LS6 Block
Callies Forged DragonSlayer Crankshaft
Scat Forged H Beam Rods
Mahle Forged Pistons w/4 cc valve reliefs
Precision Race Componets Stage 2.5 CNC'd 5.3 heads milled to a 59 cc combustion chamber 2.02/1.575 valves
Comp Cam 239/242 dur .649"/.609" 111 LSA
Comp 7.375 Hardend push rods
GM LS7 replacement lifters
Kooks 1 3/4" x 1 7/8" stepped headers w/ off road Y-pipe and 3" Flowmaster Super 40
Lucas 42# Flowmatched injectors
Fast 90mm intake
Nick Williams 90mm Throtle body
Rollmaster Double Roller timing chain
TSP Ported LS6 oil pump
ARP Head and Main Studs (12 point)
SLP Pulley
Toyo Drag Radials
Built by HKE
Tuned by RPM - 458 rwhp 432 rwtq
The car is in really good condition. I believe it was in a minor accident from the previous owner. But it wasn't bad. Still has a clean title (in-hand). I don't have the rollcage installed right now. But I do still have it. Also, it's a 99 and the body has 130k and the motor is right around 6500. Located in North Texas.
Old May 17, 2009 | 09:56 PM
Luke03's Avatar
hmmmmmm.......
Old May 17, 2009 | 10:48 PM
Noah Burns's Avatar
what ci is the motor?
Old May 17, 2009 | 11:03 PM
texasbullseye89's Avatar
Here is mine if interested.
https://www.performancetrucks.net/fo...d.php?t=441168
Old May 18, 2009 | 07:00 PM
Powerhouse's Avatar
It's a 346. It was built with the intention to run nitrous.
Also, texasbull- nic truck, but im really wanting an extended cab or 4door. Although I may consider some rcsb's.
Old May 18, 2009 | 07:33 PM
not a problem. let me know. if it doesnt sell soon its getting a little work done to it and then is going off market.
Old May 18, 2009 | 09:26 PM
Noah Burns's Avatar
damn, wish I could think of a way to do this with my Crew Cab and not lose my ***... nice car, and decent numbers from a 346
Old May 19, 2009 | 04:40 PM
Powerhouse's Avatar
I also forgot this stuff!
Trans:
Tremec T-56 six speed (Stock as far as I know) Shifts perfect though.
Pro 5.0 Shifter
McLeod Street Twin Borg & Beck Clutch
McLeod Adj Master Cylinder
New GM Slave Cylinder
Rear:
GM 10 bolt w/ 3.73 ratio
Brakes:
Bear Eradi-Speed cross drilled and slotted rotors (2 piece front, 1 piece rear
Hawk HPS Pads
Body:
BMR weld in subframe connectors
Wolf Racecraft 6 point bolt in roll bar (can be removed in about 1 1/2 hours)
Old May 19, 2009 | 05:09 PM
viciousknid's Avatar
Where's the Beef?
3 threads? Seriously? Hows anyone supposed to keep up to date on questions asked if they have to check 3 different threads?
Old May 19, 2009 | 05:14 PM
Powerhouse's Avatar
My bad. Just trying to get the word out.
