Texas We've Seceded from the Union
help with install?
Old 01-19-2009, 07:35 PM
texasbullseye89's Avatar
in the shopping cart. cam package deal from texas-speed. just waiting for funds to arrive.
Old 01-26-2009, 02:27 PM
time to bump it up. Funds have entered the bank account.
List of items I plan on ordering from texas-speed. add anything else I might need.
TSP camshaft, 918 springs, and pushrod package
camshaft bolt and package kit
Pacesetter LT headers and ORY pipe
on the cam I'm debating between the 224R and the 228R on a 112 LSA
Old 01-26-2009, 02:47 PM
95 bright teal's Avatar
Are you putting this in a 5.3? do you plan on running a stall?
Old 01-26-2009, 03:15 PM
4.8 manual transmission
Old 01-26-2009, 03:20 PM
I wouldnt go bigger than the 224R even with that cam you will need to spin the motor up past 6000 to make peak power. Ill see if i can find black gmc's dyno sheets, he has a similar cam
Old 01-26-2009, 03:23 PM
here is his dyno with a 222/224 .56X/.56X @ 112+2
so with his he sees peak power over 6000, which is fine if that is what your looking for
Old 01-26-2009, 03:51 PM
I'm not aiming for peak Hp or anything really. Just looking for a quick DD. Way down the line a 6.0 with alot of work will be going in if I keep the truck long enough.
Oh, and I'm hoping to actually make it to Wheatley's shop to get tuned, After all this is put in of course. Would I have a big problem driving there?
Old 01-27-2009, 10:27 PM
Un-Registered User
mcfarlnd's Avatar
with a 224 or 228 you will have alot of fun trying to keep it running at a stop youll prolly end up killing it a few times so, try not to pull out in front of someone just in case it decides to stall out
Old 01-27-2009, 10:58 PM
tune with a slightly higher idle may help right?
Old 02-07-2009, 02:32 PM
ok time to bump this up. zzebes is your offer still up? still needing someone to install. a local shop quoted me 320 to install headers and y-pipe if i bring every single bolt and gasket. definitely need a friend to help out here.
Quick Reply: help with install?
