Texas We've Seceded from the Union
driveshaft shop in DFW?
Old May 12, 2010 | 12:05 PM
fastrt's Avatar
11 Second Truck Club
Default driveshaft shop in DFW?
I am looking for names and numbers of GOOD drive shaft shops in DFW. I need one that does high speed balancing! not normal truck/heavy duty driveline shops. I have been pulling my hair out over my vibration at 90-115. only option left is driveshaft, seeing that I had a heavy duty truck shop balance it with new spicer u-joints in it. any help would be appreciated.
Old May 12, 2010 | 12:26 PM
bigboy576103's Avatar
Dont look like there is many out there in Dfw man i've been lookin online and nothing pops up. i did happen to find this site and gives couple sources you could get the number and call i guess...
http://www.magicyellow.com/category/...)/Waco_TX.html
If i find anything else out ill let you know!!
Old May 12, 2010 | 12:27 PM
dlt76028's Avatar
ftw gear & axle
Old May 12, 2010 | 12:31 PM
fastrt's Avatar
i talked to driveshaft specialist out of san antonio, and they said the place i had mine done more than likely bent an ear on the u joint flange putting them in, cause there were hammer marks on my drive shaft when i got it back from them.
They dont do high speed balancing (well thats what they told me anyhow) they just do standard driveshafts, and if they find out what your doing with it warranty is voided. I found out the hard way..
Old May 12, 2010 | 12:32 PM
fastrt's Avatar
Originally Posted by dlt76028
ftw gear & axle
yeah, but they dont do high speed balancing. they make a good stock replacement though.
Old May 12, 2010 | 12:36 PM
dlt76028's Avatar
I've never heard of balancer going faster then ~3500rpm... And I've called alot of driveshaft shops.
Old May 12, 2010 | 01:11 PM
fastrt's Avatar
high speed goes to 6000rpm, or equivalent of 200mph. you have to go to a performance driveline shop. all the ones around here are truck driveline shops. so far anyways.
Old May 12, 2010 | 06:33 PM
Low_S-10's Avatar
call LenMar Motorsports 817-466-9942 and ask them, they should know of a place
Old May 12, 2010 | 10:17 PM
fastrt's Avatar
thanks man, i will do that tomorrow!
