How to: Make traction bars
I made these for my S10 but the same can be done for a fullsize. I have two buddies that have this same set-up on their Cummins with tons of luck.
Here is what I started with.
3 Point hitch Top link for a tractor (2)
Rectangle tubing
Square tubing (I used this so I could turn/load the bar)
Flat steel
3/4" bolts (4)
Longer U-bolts for the rear axle (I was swapping my axle so I had them made longer)
Then I cut the top link in half.
I cut part of some square tubing so I could use them to adjust the traction bars.
Then welded them in the middle (just spot welded)
I took the top link and screwed it all the way in and then drilled holes to fill weld to make the ends stronger on the rod. Right now I am just spot welding everything and I will weld all around the ends.
The rear mount without a hole for the bolt
Front mount without the hole
The square tube welded on so I can pre-load and adjust the springs
Some mock up pics
Lowest point of the bar in front of the rear wheel
The height of the front mount
Continued....
Rectangle tubing
Flat steel
3/4" bolts (4)
Some mock up pics
Continued....
This setup bolts to the bottom of the axel with the U-bolt and then attaches to the frame in the front. I have zero axel wrap, zero wheel hop and these make this thing plant the rear.
I don't know for sure. They do make the caltrac bars for them but i wanted something that did the same but pulled up on the front while pushing down on the rear. I do know that a company make these for the 1500 but they do for the duramax trucks.
yea the fords use this setup and it works very very well. idk why someone doesnt make a set for GM trucks. they would make a killing.
im ify with caltrac. iv seen them bend and or break or not help as much as they should. i rather have a long bar setup like pictured above.
