How to: Make traction bars
18 Attachment(s)
I made these for my S10 but the same can be done for a fullsize. I have two buddies that have this same set-up on their Cummins with tons of luck.
Here is what I started with. 3 Point hitch Top link for a tractor (2) Rectangle tubing Square tubing (I used this so I could turn/load the bar) Flat steel 3/4" bolts (4) Longer U-bolts for the rear axle (I was swapping my axle so I had them made longer) Attachment 112723 Attachment 112724 Attachment 112725 Then I cut the top link in half. Attachment 112726 I cut part of some square tubing so I could use them to adjust the traction bars. Attachment 112727 Then welded them in the middle (just spot welded) Attachment 112728 I took the top link and screwed it all the way in and then drilled holes to fill weld to make the ends stronger on the rod. Right now I am just spot welding everything and I will weld all around the ends. Attachment 112729 Attachment 112730 The rear mount without a hole for the bolt Attachment 112731 Front mount without the hole Attachment 112732 The square tube welded on so I can pre-load and adjust the springs Attachment 112733 Some mock up pics Attachment 112734 Attachment 112735 Lowest point of the bar in front of the rear wheel Attachment 112736 The height of the front mount Attachment 112737 Attachment 112738 Attachment 112739 Attachment 112740 Continued.... |
5 Attachment(s)
I measured from center bolt to center bolt.
Attachment 112718 Attachment 112719 Attachment 112720 Finished look Attachment 112721 Attachment 112722 |
So this setup is bolted to the frame and not the front leaf bolt? I guess as long as it prevents axle wrap its good correct?
nice setup. does any company make long bars for 99-06 1500 anyways? i know they make them for fords.
s10 looks badass. always wanted to do a s10 like that but it becomes pita with a turbo and whatnot in that engine bay. |
Originally Posted by RS/SS 4.8
(Post 5129602)
Originally Posted by Blackbird-WS6
(Post 5129627)
yea the fords use this setup and it works very very well. idk why someone doesnt make a set for GM trucks. they would make a killing.
im ify with caltrac. iv seen them bend and or break or not help as much as they should. i rather have a long bar setup like pictured above. |
(Post 5129819)
Is there a certain length and or angle to shoot for on the bar?
Good write up!
