Whining sound ??
Old Apr 11, 2008 | 10:40 AM
03GMC's Avatar
Default Whining sound ??
This has just recently started. I have had my amp and subs in for over 6 months. Now I get this interference type sound from the speakers. So annoying. Just a bad ground here or what??
Old Apr 11, 2008 | 02:45 PM
califrog310's Avatar
That could be the problem. Check out this article from caraudio it has some very helpful info and solutions
http://www.caraudio.com/forum/showthread.php?t=198477
Old Apr 12, 2008 | 12:55 AM
53bowtie's Avatar
possibly a ground has become loose....also make sure you dont have any speaker wire running next to your power wire going to your sub amp. if you must cross speaker wire with power wire do it at a 90 degree angle with 2 zip ties.....
Old Apr 15, 2008 | 11:52 AM
BassBaller5's Avatar
speaker wire can run next to power wire all day as your speaker wire dosent carry signal.
Its interconnects you need to worry about (and the concern is running next to wires for motors (seats, windows, etc).
Deffinatly upgrade your amp grounds and one most people miss, your stock headunit ground! the common ground used in your harness is pretty shitty. Upgrading this to a well known ground spot in your truck can do wonders for noise reduction.
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Rockrz
Sep 29, 2015 09:07 AM
