Adding subs question
Old Mar 17, 2008 | 07:29 PM
Default Adding subs question
I have a 2007 new body style crew cab. How would I go about putting in subs? What I am wondering is if there is any product out there that would plug in the harness somewhere that will give me the signal I need. Also has anyone put an aftermarket headunit in and how does it look?
Old Mar 18, 2008 | 08:10 PM
53bowtie's Avatar
if you are wanting to keep the stock head unit you can put a simple line output converter hooked to any of the 4 set of speaker wire.....if you want to get a little better sound you can wire in a re-Q or clean sweep. line outputs run around $25 with the re-Q and clean sweep considerably more...
this all assuming you dont have bose.....
Old Mar 18, 2008 | 10:02 PM
Chance883's Avatar
I just had an aftermarket put in my 07, and it sticks out about a 1/4 of an inch. If I wouldve known it was going to do that I wouldve left the stock cd player in it.
Old Mar 19, 2008 | 05:23 AM
Did you put it in to use the line outs? Do you have any pics? And finally what headunit did you use?
Old Mar 19, 2008 | 09:20 AM
larsy87's Avatar
apple bottom jeans
If you put in an after market HU, you won't need a LOC. You'll be able to go RCA to RCAs.
LOC's are for stock decks that don't have RCA's and need the signal converted to rca. I always suggest an aftermarket deck, unless you like the look of the stock
Old Mar 19, 2008 | 04:33 PM
Chance883's Avatar
I went with a Kenwood DDX512. I will try to take some pics of it.
Old Apr 3, 2008 | 04:25 PM
mcgin014's Avatar
I plan on doing the same thing as the Original Poster. I am using the stock deck, non-bose but I was wondering if anyone knows that colors the speaker wires are and what ones are negative and positive. I do have a Line Out Converter
Old Apr 15, 2008 | 11:54 AM
BassBaller5's Avatar
for wiring colors...
Driver Passenger
TAN (+) L GREEN Front
GRAY (-) D GREEN
BROWN (+) BLUE Rear
YELLOW (-) LT BLUE
but know that mixing up pos and neg wont do you harm.
RJaxtheimer
Oct 31, 2015 07:58 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
00pooterSS
Jul 16, 2015 03:03 PM
