What would cause my amp to cut out??
Old Feb 26, 2007 | 08:52 PM
  #21
2002C5COUPE's Avatar
im going to wire it like this:
1. amp + to voice coil 1 +
2. voice coil 1 - to voice coil 2 +
3. voice coil 2 - to amp -
i hope this ^^ makes sense, and doesn't catch my truck on fire or anything, lol.
Old Feb 26, 2007 | 08:54 PM
  #22
LesPaul's Avatar
Originally Posted by CHEVRACER83
But Les His Amp Is Only Stable To 4 Ohm
damn my dumb ***..... not only that... that wiring he is running will result in 1 ohm... no way that amp will run that..
what you need to do is hook up the + channel to + coil and same for - on the same coil.... then wire your - + together on the other coil
sorry i have a problem with not reading everything in a post... im a "skimmer"
Old Feb 26, 2007 | 08:57 PM
  #23
LesPaul's Avatar
This is it
BTW... this thread has made me feel dumb... i got confused somewhere in here.... this is **** a computer engineer should do while he sleeps..
Old Feb 26, 2007 | 08:59 PM
  #24
ok thanks a lot guys!
im surprised i havent messed that amp up by running around so long with it like this!
Old Feb 26, 2007 | 10:28 PM
  #25
'89ChevyMadneSS's Avatar
hence the two warrantied amps
jfwy!
that fosgate diagram could be really handy!
Old Feb 26, 2007 | 11:17 PM
  #26
jfwy!
lol yeah you would think so, but i was having completely different problems with them.
Old Feb 26, 2007 | 11:21 PM
  #27
CHEVRACER83's Avatar
yeah ive ran many amps past the ohms they were designed for but that stress can only go on for so long
Old Feb 27, 2007 | 05:44 PM
  #28
ok i rewired my sub to run in series, then i put it all back in and tried it out and............nothing! lol
it sucked
i took it back out and found a voice coil wire had broke off of the terminal, i rigged it back up, and it works now
it's 1,000,000x better than before when it was running at 2 ohms! lol
thanks again for the help!
Old Feb 27, 2007 | 07:24 PM
  #29
no problem.... glad you got it wired back up... and your amp will thank you too
Old Mar 5, 2007 | 11:27 PM
  #30
Chevy_Truck_Man's Avatar
Run the coils in a series and it will work fine
