what else do i need?
Old Oct 12, 2008 | 11:59 AM
lo&sloSierra's Avatar
Default what else do i need?
Im have a 03 regular cab, stock head unit, and cab speakers, no power windows, stock alternator, I am putting in 2 CVT 12's on a 1000 watt amp, and 2 comp 10's on a 450 watt amp, what do i need to run power and rca's to both amps and what type of fuse block(if thats what its called) will i need?
links would be wonderful, anything else im missing?
Old Oct 12, 2008 | 12:03 PM
00ChevyScott's Avatar
Wearin' da big hat
are you planning on putting all 4 of those in your truck?
If so, don't do it. You never want to mix sub sizes unless you're going with say, an 8" midbass driver in the doors or something.
Old Oct 12, 2008 | 12:40 PM
BassBaller5's Avatar
x2, mixing sub sizes AND types is a big no no unless done correctly.
Not to mention running everything off stock headunit with no amp on the speakers...
Old Oct 12, 2008 | 12:44 PM
****, ok change it, I want to run 3 CVT 12's, should i run 2 amps or 1200 on 2 and my 450 on one, or all three on the same amp? what all will i need? (2 behind the seats and one in the center console.)
Old Oct 12, 2008 | 12:46 PM
RandomHero's Avatar
Are you planning on doing a blow through? The CVTs still require a fair amount of airspace and 2 12's with the right box will sound much better than 3 12s in a shitty box with no airspace.
Old Oct 12, 2008 | 02:48 PM
Just as bad as mixing sub sizes/types would be putting two different amps to some identical subs.
Either use amps that are identical and can run slave to another amp, or run one large amp to all the subs.
Old Oct 12, 2008 | 05:00 PM
its not a cut through, but they will have plenty of airspace, who makes a good amp that i could power all three 12" CVT's?
Old Oct 12, 2008 | 05:13 PM
95 bright teal's Avatar
Do you have a box made? I hope its sealed, because i know there isnt enough room for a properly set up ported 12" enclosure behind the seats.
Old Oct 12, 2008 | 08:33 PM
14psisupra's Avatar
for running 3 subs you want a single channel amp right? which they can get rather spendy.
Old Oct 12, 2008 | 08:35 PM
yea i have the box half way made, it is going to be sealed though, question should i do a shared space with the three of them or seperate each one?
