what else do i need?
Old Oct 12, 2008 | 08:36 PM
lo&sloSierra's Avatar
yea you want a mono channel amp and they get expensive
Old Oct 13, 2008 | 08:55 AM
blueflamed03's Avatar
Originally Posted by RandomHero
Are you planning on doing a blow through? The CVTs still require a fair amount of airspace and 2 12's with the right box will sound much better than 3 12s in a shitty box with no airspace.
you may be thinking L7, the CVT is the slim line, that can work in .88 sealed per driver.
Old Oct 13, 2008 | 08:56 AM
you get what you pay for...wanna run three woofers, get an amp that will do roughly 1200 watts...and power all three.
Old Oct 13, 2008 | 10:02 AM
ok well now the question is should i put the three in one big box sharing space, or should i put a wall between each one? ive seen 4 cvr 8" sharing space in a regular cab and it sounded good, but doesnt it cause the speakers to sorta fight each other for air?
Old Oct 13, 2008 | 10:09 AM
BassBaller5's Avatar
unless you have the ability to make each seperate box with the EXACT same airspace, i would build one large box. You wont see any troubles with the subs "competing" for air.
Old Oct 13, 2008 | 01:00 PM
ok thanks
Old Oct 13, 2008 | 01:19 PM
common chamber is fine
Old Oct 13, 2008 | 01:23 PM
viciousknid's Avatar
Where's the Beef?
In highschool a guy in my class had 3 or 4 (cant remember) JL 12"s behind the seat of his RCSB Dodge Ram. I think he was running 1 1200 watt amp and the subs shared air.
He'd leave it turned down because even 8"s sound GREAT in a regular cab.
Around graduation someone borrowed his truck to go to the store. They realized he had a system and rolled the windows down and radio up. You could hear every single thump bump and groan all the way to the store, and all the way back.
2 blocks away and you could still feel the vibration on the building and it sounded like they were in the parking lot.
I'd go with 2.
Old Oct 13, 2008 | 01:26 PM
larsy87's Avatar
apple bottom jeans
The only thing you have to watch out for is if you lose a sub in shared airpsace, you'll probably lose the other one. Common airspace is fine though.
Old Oct 13, 2008 | 01:27 PM
RandomHero's Avatar
I'd go with 2.
