What color wire for the A/C fan turn on
Old Jul 16, 2006 | 11:21 PM
Question What color wire for the A/C fan turn on
I have an 02 GMC sierra and was wondering which wire do I use for the A.C fan turn on, Ive read that its a green and white one in the fuse box under the hood. theyre alot of green and white wires in the fuse box. can anyone show me some pics of where exactly the wire you guys use is. Id aperciate it, thanks.
Old Jul 16, 2006 | 11:23 PM
Z284thgen's Avatar
11 Second Club
its the solid green wire thats in the harness that comes up from the bottom of the motor right by the lil red power supply box on the DS of the motor
Old Jul 16, 2006 | 11:38 PM
thanks, any pics? just to make sure.
Old Jul 17, 2006 | 12:02 AM
Z284thgen's Avatar
11 Second Club
someone has some on here somewhere might try a search for fan harness and i bet you find it
Old Jul 17, 2006 | 12:40 AM
usmcchevy's Avatar
minus stupid. If you can't find a pic just open up the wire loom that goes right by the red junction box, theres only one solid dark green wire in there.
Old Jul 17, 2006 | 07:21 AM
thanks, later.
Old Jul 17, 2006 | 01:04 PM
CoonToot's Avatar
This should help...
My green wire was found here
Old Aug 3, 2006 | 09:34 PM
SnakeOiler's Avatar
Depends on how you want to signal your fan to turn on. Using the green wire (noted in the picture above), this is the actual power wire for the a/c compressor. Lots of people use this one.
Two pins over from that wire is a green w/white wire. This is the ground signal wire for the a/c compressor relay. You can use this to do the same for your own a/c fan relay. This is what I use.
Corvette454l88
Sep 1, 2016 01:24 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
mr03silverado
Jul 17, 2015 02:15 PM
