What causes the signal lights to stay on?
Why are my interior signal lights staying on when the lights are on? I know that it'll do that if theres a bulb burnt out but theres not. It all started when I changed the bulbs to those new style LED 360 degree bulbs. 4 in the rear and 2 in the front. At first a couple didn't work then I 180 the bulb and got them to work. Now the side marker lights don't seem as bright as they used to. I changed them back to the ones that I had in there before and that didn't change anything except that sometimes I blow the left turn and the stop lamp fuses. If I have the lights on all the lights work but my turn signals don't flash, they work normal with the lights off. There might be a wiring problem somewhere but I don't know
Sounds like the led's are causing your problems. The draw so much less current that the pcu thinks it has bulbs out. That doesn't explain why you are blowing fuses though. You might need to put resistors in with the leds to draw more current so the truck knows they are there.
I'm sure they fit in the slot but just the fact that they draw less current confuses the computer into believing there is a bad bulb. It is not a problem with all led's and the APC's might have had a built in resistor to solve the problem or just happen to draw enough of current to not cause a problem. I believe you can get pre-made resistor kits to solve the problem. If you want to check your truck out and make sure it is working properly you can always put stock bulbs back in all of the sockets and see if it opperates correctly. If it still has problems then its would be time to start looking into the wiring. I highly suspect it is the new led's causing your problems though.
are you using the correct bulbs in the correct places your turn signal bulbs i believe are 3156 which in a normal bulb would be a dual filament bulb. also if your brake lights would be 56 as well so i would double check what you have in there. go to sylvania.com to find a fitment guide for your vehicle. also apc stuff is crappy check vleds.com or autolumination.com or superbrightleds.com all three sites are good i just ordered some from vleds myself and i have had them for a while they work well. also you do need the resistors i think all the sites sell them and they are like no more then 5 or 8 bucks. my tails are leds that i bought off of ebay the whole top of the tail is leds and the turn signal and the reverse lights are regular bulbs. if you have any other questions ill help you the best i can pm me or email me at dlawson@patmedia.net Ps u can also go to the auto parts store and purchase a new flasher for it as well but i just put the resistors in myself it was easier takes five minutes to install.
I went to the sylvania website an found the guide, and it shows that I use the 3167 bulbs. I'll try the turn signal flasher and if that don't work the resister thingie.
Auto Lamp Replacement Guide - Results
Head straight to Amazon.com and purchase the SilverStar or Xenarc products that fit your vehicle. Or print out the list and find them at your nearest retailer.
2000 CHEVROLET Pickup, Silverado
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen Upgrade: Up to 20% Brighter
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
3157A
3157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
3157NALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
3157A
Rear turn signal
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
3157LL
Tail light
1157
3157LL
Stop light
1157
3157LL
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
880
880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
97
Back up light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
1156
3156
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
3157A
Ash tray
194
Glove box
194
Map light
168
211-2
Dome light
211-2
Step/Courtesy light
1003
1003LL Long Life Upgrade: Up to twice the life of the standard lamp
211-2
74
Trunk/Cargo area
912
Under hood light
89
93
Instrument-general
161
194
74
Check engine indicator
74
Hi-beam indicator
74
Seat belt indicator
74
Brake warning
74
Automatic transmission indicator
161
Directional signal indicator
74
Daytime running lights
4114LL
Low beam headlamp
9006
High beam headlamp
9005
Parking light
3157A
Front turn signal
3157A
Rear turn signal
1157
3157LL
Tail light
1157
3157LL
Stop light
1157
3157LL
921
Fog/Driving light
880
License plate
194
97
Back up light
1156
1156
3156
Front sidemarker
3157A
Ash tray
194
Glove box
194
Map light
168
211-2
Dome light
211-2
Step/Courtesy light
1003
211-2
74
Trunk/Cargo area
912
Under hood light
89
93
Instrument-general
161
194
74
74
Hi-beam indicator
74
Seat belt indicator
74
Brake warning
74
161
74
4114LL
I went to NAPA as thathe the only parts store for hours around and that don't offer any other flasher. Is there a part number and brand then mabey I can get them to order it.
carid
Oct 28, 2015 08:24 AM
MA$TER_E
Sep 9, 2015 03:14 PM
