what amp?
Old May 10, 2006 | 11:58 PM
Coban's Avatar
Default what amp?
How do you match the amplifier to the sub? I have a 12" Rockford Fosgate Power Series 4 ohm and need a amp for it. It is 600 Wrms and 1200 Wpeak.
Old May 11, 2006 | 01:47 AM
thunder550's Avatar
High on diesel fumes
Is your sub a dual voice coil or single?
Old May 11, 2006 | 09:02 AM
04BlackGmc's Avatar
10 Second Club
you want to over power the sub some what for it doesnt have to work as hard.
Old May 11, 2006 | 10:06 AM
SBChevrolet's Avatar
agreed plus you it will be more clear if you dont have the gain turned all the way up Check out the Kenwood 9102
Old May 11, 2006 | 10:11 AM
04BlackGmc's Avatar
10 Second Club
very true. i have a 400RMs 800 max sub with a 1500 watt amp, bridged at 900 watts at 4 ohms only turned half way up.
Old May 11, 2006 | 11:07 AM
thunder550's Avatar
If your sub is SVC I'd recommend somewhere between a 600x2 and 800x2 RMS amp. If it's DVC I'd recommend a mono 600-800 watt RMS amp. You can definitely go bigger if you have the budget for it, the bigger you go, the less you drive the amp and the clearer sound you will get, as the other guys said above. Definitely don't under-power it though, contrary to popular belief it's easier to blow a sub by under-powering it than over-powering it.
I have 2 500watt RMS subs pushed by a 1600 RMS amp, gain is set low and it will last forever....
Texas5.3_1251
Mar 5, 2016 08:10 PM
mzoomora
Jan 3, 2016 07:06 AM
CD82
Oct 23, 2015 07:32 AM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
