variable fan blower?
Old Jul 19, 2008 | 05:24 PM
venomhp's Avatar
Default variable fan blower?
Ive been having an issue, its not really critical but more annoying than anything. Just having the a/c on any setting the blower speed will slow down but the voltage wont change, and then after a while it will come back to speed without any other changes. It didnt used to do this I dont think, or else its a lot more noticeable now. anyone know how to fix this?
Old Jul 19, 2008 | 11:26 PM
53bowtie's Avatar
would almost bet it the fan blower resistor. it is located under the dash behind the glove box by the blower motor. it shouldnt be very expensive and only a couple screws to hold it in. check and see if you are getting 12 volts AND ground at the resistor. if so then it is the resistor as it is the only thing that controls the fan speed.
Old Jul 21, 2008 | 02:57 PM
change the resistor and order the harness for the resistor. Guarantee you when you pull it apart you will find that the harness has melted at the resistor assembly.
Old Jul 21, 2008 | 03:34 PM
venomhp's Avatar
ill have to check it out in the next few weeks, thanks guys!
calsdad
Jun 14, 2023 11:07 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Silver8ado
Sep 30, 2015 11:42 AM
old motorhead
Sep 29, 2015 08:22 PM
