Turn off lights
Old Sep 24, 2010 | 11:56 PM
zittman's Avatar
Default Turn off lights
I have a 00 Silverado and was wondering if there is a switch or a way to turn my headlights off when I wanted to without pushing in the park brake. I know on the newer models the switch allows you to turn them off. Just curious. Thanks.
Old Sep 25, 2010 | 12:30 AM
Cooder5.3's Avatar
Push the dome override button 5 times after the start your truck. But when you turn the truck off they come on automatically again.
Old Sep 25, 2010 | 09:23 AM
jared91's Avatar
4 not 5.
Old Sep 25, 2010 | 10:03 AM
Formerly 99-2door-08/30/2010
Originally Posted by jared91
4 not 5.
3 not 4 or 5
Old Sep 25, 2010 | 10:09 AM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by PitchblackC3
3 not 4 or 5
But if you only press it 3 times, your dome light will be off
Old Sep 25, 2010 | 10:17 AM
Not if it started out off....:nunchuk1:
Old Sep 25, 2010 | 09:20 PM
zittman's Avatar
Ok, so there is not a switch that I can purchase like the newer ones to do so??? Just push the dome override button like 4 or 5 times. Thanks. If there is another way to do so with a switch it would be easier.
Old Sep 26, 2010 | 07:36 PM
KleenHall's Avatar
push in, out, in ,out
aaaaannnnd since its the dome orverride the dome will never some on or go off, unless the door is open...geez
this also turns off the daytime running lights, ^^^^do that before you pull the E brake out and the lights will be off, then use the switch or the button trick again
Old Sep 26, 2010 | 08:37 PM
skolman91's Avatar
Search and you will find a way to disable the the automatic headlights if thats what your asking. Jump two pins on the bcm and its disabled, i used a paper clip. After that your headlights wont be on unless you want them to be, DRL still work tho when in gear..
Old Oct 7, 2010 | 11:35 PM
Ender06's Avatar
Exactly...but I dont know about a paper clip. I used a 1.5komh resistor (5 for $1.50 at radio shaq) in the bcm. U dont need to remove any dash panels or anything. Just crall under the driverside dash and there is the BCM with 3 plugs going into it. Pull the Purple plug out, shoud be the one towards the inside of the truck (towards the center console) and put one of the resistors in from the back of the plug. Put it in the white wire and the gray wire. There are 2 gray wires, make sure and use the gray wire furthest from the white wire. Then plug all back in and you're good to go. Takes 5min tops.
