Tach wiring???
Old Mar 30, 2006 | 12:27 PM
smooth_addictions's Avatar
Default Tach wiring???
ok so i got all of my tach wired in exept the green wire that is supposed to go to the coil. autometer says that you have to use a module for distributerless ignition. im thinkin that there is got to be a way around that. so guys with tachs let me know where you ran your wiring. thanks
Old Mar 30, 2006 | 02:35 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
rpm signal wire for the tach is white going into the back of the cluster I believe thats what the green wire on the autometer gauge is for if so then splice into the white wire and you will have a working tach.
Old Mar 30, 2006 | 04:26 PM
sweet i will give it a try tonight
Old Mar 30, 2006 | 04:41 PM
sikchevy's Avatar
that was easy. i was way off
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
