sub outs blown???
Old Jun 29, 2007 | 06:24 AM
dropkick13's Avatar
Default sub outs blown???
My amp powers on but my subs do not get power. I used a multi meter and found that i get approx 12.5 volts battery/ground and same with remote/ground but at both of my sub output terminals it constantly fluctuates between low negative to low positive numbers. (yes, even though its a mono amp, there are two sub outputs because of internal parallel wiring). would this show me there's a problem? if so, what is it? how can i fix it?
Old Jun 29, 2007 | 08:18 PM
53bowtie's Avatar
check to see if the subs are blown using the ohm setting on the multi meter.....if they are 4 ohms then it should read around 4 ohm, if subs are 2 ohm it should read around 2 ohm, etc.....if it is less than half the ohm load or doesnt register at all then your subs are blown. If your subs check to be fine then it is either your speaker wire or rca's. check this by setting the multi meter to +/- setting so the leads beeps when touching each other. touch the speaker wire and rca's, one of them wont beep b/c there is a break in the wire somewhere. which ever one doesnt beep change it out and youll be good to go.....
Old Jul 1, 2007 | 09:45 PM
dropkick13's Avatar
the subs work with a different amp...everything the same except i swap the amps
Old Jul 1, 2007 | 10:45 PM
53bowtie's Avatar
prolly rca's then, pull your radio out and run a diff. set from the radio to your amp......
Old Jul 2, 2007 | 01:41 PM
dropkick13's Avatar
but the rca's work fine when i run my smaller amp
Old Jul 2, 2007 | 01:57 PM
SmokedSierra01's Avatar
Try wiring your sub into a series connections with your amp. If that doesn't work then wire the sub into a parallel connection with your amp.
Old Jul 2, 2007 | 09:59 PM
53bowtie's Avatar
sub wiring wouldnt have anything to do with it if it worked properly before......sounds to me like its the amp man........thats about the only thing we havent eliminated yet....
Old Jul 3, 2007 | 12:36 AM
dropkick13's Avatar
yea i guess it's the amp but the sub outputs are fine (checked by multi meter) as well as everything else. I've even gone through and checked for signs that i might be retarded (made sure the gain was up some) and i just cant figure this out. Well, I'm moving on with buying all the wiring the amp 'wants' and maybe this will change things (distro blocks to run dual 4 ga instead of a 'shitty' connection with 0 ga)
Old Jul 3, 2007 | 10:35 PM
53bowtie's Avatar
sounds good man...
ferrellrooster
Mar 6, 2025 03:22 PM
fastjweb
Aug 15, 2015 10:47 AM
BIGD4504
Jul 28, 2015 11:46 AM
atxlt
Jul 20, 2015 11:06 PM
Mzay
Jul 6, 2015 11:03 PM
