is this sub box any good? (dual 12" ext cab.)
#33
Ok so I have to wire backwards on the ab subs right? Positive from the amp to negative on the sub and negative on the amp to positive on the sub?
#37
By mounting the audiobahn subs on the box facing into the box and the kickers facing out of the box and wiring them all + to + and - to - the subs are not all moving in the same direction. The kickers would be pushing out of the box while the audiobahns are pushing into the box, and they are cancelling each other out and making no compression of air in the box. If you wire the audiobahns reverse polarity (you could reverse either set of subs, the kickers or audiobahns) it will make them pull out while the kickers push out, so the cones will all be moving the same direction.
Make sense?
Give it a shot and let us know.
Make sense?
#38
Finally got a chance to work on my truck today. I fliped the kickers and rewired the ab's and it worked. I can actually sit people back there now lol but thanks fellas!
Raggedz71
07-29-2016 10:20 AM
Suburban2500
07-19-2015 04:50 PM
