Stereo Deck Keeps Blowning
Old Jun 16, 2016 | 10:41 AM
RA62025's Avatar
Banned
Default Stereo Deck Keeps Blowning
I recently got a deck in my work truck 2007 Classic. I did the job myself with the kit that keeps the door chime. Everything was working fine. Than 1 day later it stopped working I checked the fuse because the aux fuse blew a few days before that and it was blown. The stereo went about 3 weeks with out blowing a fuse until recently I did a Cam Swap and ever since then the fuse will blow every time I start my engine. When I just turn the key into the ON position it's fine but when the engine turns over the fuse is blown. Any ideas?
I have a Pioneer Deck and a 2007 Reg Cab Sierra 1500 Classic
Old Jun 16, 2016 | 04:30 PM
Suburbazine's Avatar
My guess would be faulty ignition switch.
Old Jun 16, 2016 | 09:54 PM
Flewbyu123's Avatar
what brand of harness is it? I would check all connections. When all the are right.. change the harness out!
Old Jun 20, 2016 | 01:37 PM
RA62025's Avatar
Banned
This is the harness
CRUX SOCGM-17 Wiring Interface Allows you to connect a new car stereo and retains the door chimes and audible warning system in select GM vehicles at Crutchfield.com
Crux SOCGM
What gets me is when I plug in a new fuse and just turn the truck to the "ON" position it is fine. The fuse gets blown when I try to start my truck. The fuse only last 2 start ups. Would the harness still be the one at fault. Going to take apart the dash and see if there are any bare wires but I took my sweet a$$ time doing the install to avoid this kind of thing.
Old Jun 20, 2016 | 06:44 PM
Like I suggested earlier, just replace the electrical part of the ignition switch. This is a pretty common failure when the contacts go bad. Even on the 03-07 trucks with their low-amperage switches, you can still short out the radio accidentally.
Old Jun 20, 2016 | 06:50 PM
RA62025's Avatar
Banned
Ok I have never replaced that part of a car before do you have a part # for it?
Old Jun 20, 2016 | 08:23 PM
Ls1115
Old Jun 20, 2016 | 10:27 PM
Flewbyu123's Avatar
I've seen this before.. I'm a install manager. I had one that would lock up and my windows would roll up or down.. etc.. So unless you have a bad deck.. you wanna check it.. I can tell you how to wire a relay off the bcm the same as that's doing only the relay is much stronger than the small cheap ones used in that harness..
Old Jun 21, 2016 | 09:45 AM
RA62025's Avatar
Banned
It all seems to be working now. I put a new fuse in and it hasn't blown yet I'm now on about 6 start ups.
turbo39402
Mar 7, 2016 09:35 AM
09CamdSilvy
Mar 2, 2016 09:47 AM
GREGGO
254
Dec 7, 2004 11:18 AM
Brandon Boomhauer
Mar 8, 2002 11:46 PM
MNC5
Mar 4, 2002 09:12 PM
