Radio issues
Old Aug 23, 2008 | 07:35 PM
Blu99T/A's Avatar
Originally Posted by 53bowtie
Honestly man i would pull the radio out and test it as close to the harness as possible so you can eliminate the wire between the radio and speaker as a problem as well. Plus, IMHO it is easier to pull the radio out on those trucks than the door panel, you dont even need any tools to pull the radio out. Just a thought. Good luck.
I agree.
I convinced myself to just go ahead and replace the headunit and see if that fixes it. I would have eventually replaced it anyway to get a better tuner and to have rca preouts to run my subs.
Old Aug 24, 2008 | 07:31 PM
flossinon_24s's Avatar
his is an 03, you have 3 screws to take out to get the radio out.
Old Aug 24, 2008 | 07:40 PM
53bowtie's Avatar
My bad. I just saw the 1999 in his sig and thought that was his truck.
Old Aug 26, 2008 | 12:45 AM
Blu99T/A's Avatar
Headunit did not fix the issue, but now I have my cables and remote wire ran for my amp..
Time to pull the door panel off as the speaker wire had power at the unit.
Looks like I will be buying a new set of components now. Oh well, good excuse to upgrade that as well.
Old Aug 26, 2008 | 09:45 AM
swap the door speakers around. If the problem stays on the drivers side then it is the wiring, if it goes to the pass side then its a problem with the voice coil.
Old Aug 26, 2008 | 11:38 AM
Blu99T/A's Avatar
Good idea.
Old Aug 26, 2008 | 07:33 PM
53bowtie's Avatar
No need to swap them, just hook an ohm meter to the left front when you pull it out. should read 3-4 ohms if its not blown. If it reads lower then that or 0 then the speaker is blown if not then i may be the speaker wire.
Old Aug 26, 2008 | 11:01 PM
Blu99T/A's Avatar
I tore into the door tonight. Found the wiring good, it was hot (had power) at the end of the plug. Speaker was not working, I used a junk old 6.5" speaker that I had in the garage from the T/A, it worked great, swapped back to the original, still did not work. I tried powering the speaker bypassing the OE plug and it still did not work.
I am convinced that it is now the speaker.
any recommendations on some decently priced replacements?
Old Aug 27, 2008 | 06:38 PM
53bowtie's Avatar
infinity reference are around $100 and sound decently good off head unit power.
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
