Push Button Ignition???
Old Dec 26, 2018 | 11:15 PM
ironcityboom's Avatar
Default Push Button Ignition???
Hey Guys, I was reading up on an old push button ignition switch thread, but it seems they never came to a solution. I'm in the process of going to a Holley HP setup and since the old harness is completely gone and the Holley doesn't provide any wiring to the starter i'm trying to figure out this whole push button start. I've included a picture of my Joe's switch diagram and was hoping to utilize the wires from the stock ignition switch but I can't find a good wiring diagram to figure out which wire or wires I'd need to use for the "ignition" wire per the Joe's diagram? Truck is an 05 Silvy
Old Dec 30, 2018 | 10:46 AM
Wiring is easy extend the wires to that switch panel and wire it up. you will need a relay of ing. for 2nd wire.
and for 2nd acc. or relay pack and just signal input. Depends on what all you want.
12volts red (40A), red (40A) + ignition harness Starter yellow + ignition harness Second Starter N/A Ignition pink + ignition harness Second Ignition white + ignition harness Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system. Third Ignition N/A Accessory orange + ignition harness Second Accessory brown + ignition harness Keysense lt. green - ignition harness Power Lock use 457G or 456G module Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
Old Jan 2, 2019 | 12:56 PM
I gave it some thought. Best way would be simple relays in connectors mounted close to the ignition wires and then run the signal low voltage wires up to the panel. Simple clean and servicing would be easy.
cromedome
Feb 10, 2017 09:25 AM
TURBHOE
May 14, 2012 05:48 AM
KDavis04ss
14
Apr 25, 2012 06:23 PM
04herod
Jun 14, 2011 05:12 PM
