Mirror Temp showing "OC" instead of temp
Old Jan 13, 2019 | 09:13 AM
Rugerator's Avatar
Default Mirror Temp showing "OC" instead of temp
2005 Sierra, I had to change the engine wiring harness and now the temperature display in the mirror shows "OC". I am guessing OC is for open circuit but the compass works fine and is accurate. All the connections between the engine harness, body harness, and fuse block are good.
I found something on the Bing/google machine that says the mirror will display "OC" if the mirror senses a temperature of less than -40°C (-40°F).
the mirror will display a "SC" if the mirror senses a temperature of greater than 112°C (143°F). It is a bit chilly out but it damn sure is not 40 below.
Any Ideas?
RickLowpez
Aug 26, 2009 03:09 AM
RickLowpez
Aug 7, 2009 01:20 AM
OneQwikSS
Apr 26, 2009 11:36 PM
SlvrSierra4.8
Aug 15, 2006 08:10 PM
kwkshift
Oct 23, 2003 01:04 PM
