power wire for amp...
Old Sep 25, 2007 | 07:39 AM
2k4tahoe's Avatar
Default power wire for amp...
where did yall drill a hole in the firewall?
im trying to install a system in my girls 1999 silverado, but i wanted to know a good spot so i do drill thru some wires, LOL
thanks
Old Sep 25, 2007 | 08:53 AM
shakinlm7's Avatar
Grab a flash light and take a look under your dash. All you need is a clear spot on the firewall behind the dash. (find something coming through the fire wall that you can use to reference the spot you picked when looking at the firewall from the engine bay make sure there is nothing behind the spot you picked and you'll be good!!) I recommend drilling a hole on the drivers side, you can rout your wire under the fuse panel and even put your fuse in there if you want. Doing that made my install a lot cleaner!!
Old Sep 25, 2007 | 09:08 AM
StrokerAce03's Avatar
I ran mine through a rubber grommet on the driver's side floorboard.
Old Sep 25, 2007 | 10:07 AM
2k4tahoe's Avatar
interesting under the drivers side floor board, that would be good, cause i hate drilling holes and using gromets.
Old Sep 25, 2007 | 11:42 AM
budhayes3's Avatar
PT's Slowest Truck
What guage wire are you using? For my Basslink I was able to use the factory grommet on the driver's side, under the brake booster, where the factory harness passes through. I didn't use really big power wire though (can't remember what size actually, but definitely not like 0 guage or anything like that). If you're using some monster wire, you could drill a hole right around where that factory harness is, there's some blank space there...probably right beneath or next to the factory harness.
Here's mine...
Old Sep 25, 2007 | 11:46 AM
2k4tahoe's Avatar
i was looking at that last night, and wondered if i could sneak the wire in that. i think its like 8-10 guage, just running 1 semi small amp.
Old Sep 25, 2007 | 12:47 PM
thats how i do all mine. its simple and easy.
Old Sep 25, 2007 | 05:53 PM
TURBHOE's Avatar
on the driver side fire wall there is a flat spot perfect for drilling. on my tahoe the fire wall fiberglass insulation stuff even went around the spot. thats where i drilled a hole for my amp power wire in my silverado,tahoe, and mcfarlnd's silverado.
Old Sep 25, 2007 | 06:16 PM
Yea but remember I'm lazy. lol I like my way cuz I can wire an amp in like 10 minutes that way. I just poke through with a screwdriver and push the cable through.
Old Sep 25, 2007 | 10:38 PM
budhayes3's Avatar
PT's Slowest Truck
Yep, 8-10 guage will work...I think that's about what I have (can't remember, pretty sure I got a 10g kit). It's a little tough to sneak the wire through there, but it's do-able.
