Power window conversion
Old Mar 29, 2010 | 01:27 AM
03CHEVYBOY's Avatar
Default Power window conversion
I have an 03 4.8 ecsb base model with crank windows and need to install some power windows. Every person i have spoken to about power windows says the aftermarket kits are cheap and dont even work so those arent an option. What if i went to the dealer or bought the doors and wiring kit and paid a shop to do it? Please please help thanks
Old Mar 30, 2010 | 06:25 AM
Sc00by's Avatar
Its probably going to get expensive really quick. You would first have to buy the window regulators then all of the door switches/relays and new door panels. Power window door panels are different than the hand crank ones. So figure dealer cost of the items and dealer labor and your looking at probably close to a grand. (my guess)
Old Mar 30, 2010 | 11:17 PM
03CHEVYBOY's Avatar
i found the doors that came off of a silverado with power windows/mirrors/door locks for about 80 each which isnt bad!
Old Apr 1, 2010 | 06:19 AM
Sc00by's Avatar
Awesome! Great deal on that setup. Everything should bolt right up.
Old Apr 3, 2010 | 02:51 AM
sercastiK's Avatar
I had the spal kit, It worked damn good.
Old Apr 12, 2010 | 10:43 PM
03CHEVYBOY's Avatar
spal kit?? really?? youre the first person ive ever heard said the kit worked well! were you able to install it yourself ?
Old Apr 15, 2010 | 12:02 AM
03CHEVYBOY's Avatar
Is the spal kit from a1 electric? Becuase ive heard that was an okay brand.
Old May 5, 2010 | 11:16 PM
SST's Avatar
SST
Are trucks prewired to accept the harness? Say you got everything at a junk yard. Is it plug and play?
Old May 6, 2010 | 10:18 AM
lo&sloSierra's Avatar
they are not plug and play the harness isnt there, i've tried. im going to do power windows too, im leaving the door panels and am going to just plug the crank hole and wrap the panels and cut out a spot for the factory power window switches. Im going to build a harness for all of it and use factory switches, motor, and regulators.
lucas287
31
Jan 12, 2021 06:18 AM
Corvette454l88
Sep 1, 2016 01:24 AM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
01 5.3
Sep 2, 2015 02:17 PM
