PASSLOCK - Truck wont run
Old 04-30-2013, 05:47 AM
JFOLM's Avatar
Originally Posted by dirt track racer 81
What I don't get on mine is its very intermitted. All of a sudden now it's running and I've started it 30+ times today and its just fine..
Mine is the same way.
Old 07-05-2013, 03:31 PM
formerly Brad Eller -06/24/2013
txperformance's Avatar
I had the same issues and i ended up measuring the resistance between the key and the bcm with a multimeter and i cut the wire and spliced a resistor w/ the same ohm reading inline w/ a relay (to simulate key being turned on)... it worked like a charm. You might need to do a security relearn once you get it bypassed though. Or, you can just go in and disable VATS in your tune.. both methods worked for me.
Old 07-05-2013, 03:54 PM
dirt track racer 81's Avatar
Thanks for sharing that.. How'd you wire the relay
Old 09-27-2013, 08:50 PM
back to doing this again
stealthperf
34
02-14-2016 11:35 AM
wrb002
08-31-2015 12:00 PM
black6spdz
07-16-2015 01:32 AM
ferrellrooster
07-13-2015 09:53 AM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: PASSLOCK - Truck wont run
