Need help hooking up rca drop to stock wiring harness
Old Aug 7, 2008 | 01:51 PM
1BadA$$z28's Avatar
Default Need help hooking up rca drop to stock wiring harness
I have a 2005 dodge ram hemi that i need to hook up a sub to with the stock deck so i bought a rca drop from best buy and need to know what wires i need to hook the rca drop to?????????
Old Aug 7, 2008 | 07:20 PM
53bowtie's Avatar
If you are talking about a Line Output Converter (LOC) then you just need to find one set of speaker wires to tap into. You will not use the brown wires and since your running a sub you only need a mono signal so put the positive gray and white together and the negative gray and white together and splice them into one set of speaker wires. I have a wiring diagram for up to a 2003 Ram but i dont know if the 2005 is different or not.
Old Aug 8, 2008 | 11:06 AM
1BadA$$z28's Avatar
alright thanks 53bowtie im going to give it another go and if I cant figure it out im just going to have best buy wire it up for me for $45...
Old Aug 13, 2008 | 12:36 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
is that $45 + the part? the part is $45 itself...just buy the hi-lo converter & some t-taps & male spades & do it yourself...it's actually pretty simple
Old Aug 13, 2008 | 01:27 AM
53bowtie's Avatar
the LOC is only $25 if i remember right from best buy (if it is the one i am thinking of). op, did you get it put in?
ARC
57
Feb 21, 2022 10:54 AM
D1SCSS
Jan 25, 2016 10:14 PM
vortecyota
Jul 23, 2015 08:26 PM
Ammadien
Jul 22, 2015 08:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
