My Fuse Holder is melting and I dont know why
Old Nov 24, 2008 | 01:18 PM
Chevy432's Avatar
Default My Fuse Holder is melting and I dont know why
OK my subs went out about a week ago i figured out that my amp wasnt getting any power at all so i opened the hood to look at the fuse and found that half of the plastic fuse holder was completely melted..so i purchased a new one, installed it and low and behold it started melting again whats going on???
Old Nov 24, 2008 | 01:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
Shitty ground will do this every time, you may also want to look at the gauge wire you are using on the fuse holder.
Old Nov 24, 2008 | 03:56 PM
Breeze's Avatar
11 Second Truck Club
Old Nov 30, 2008 | 07:12 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Definitely need to check your ground. It should be short, and the same or bigger gauge wire compared to your power wire.
Old Nov 30, 2008 | 07:14 PM
viciousknid's Avatar
Where's the Beef?
Did you hook your amps up to that fuse box? Because they should be drawing from the Battery and the stereo remote wire.
Old Nov 30, 2008 | 07:17 PM
I think he means the inline fuse for his amp power wire, near the battery. At least I hope that's how it's wired.
Old Nov 30, 2008 | 08:08 PM
Where's the Beef?
AHH.. okay, i misunderstood.
I'd agree on the ground, and trace the wire to make sure you didn't cut it some where causing it to ground out.
Old Nov 30, 2008 | 08:42 PM
larsy87's Avatar
apple bottom jeans
If the power wire was grounding out to the body, the fuse wouldn't stay around long enough to melt the holder, it would just blow..or he has a **** *** fuse holder.
Old Dec 6, 2008 | 07:25 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
yeah i had that happen to me...i say check the ground & also make sure that the screws holding the fuse in are all the way down that's what it was for me my fuse was arching & that **** burnt the **** outta my hand when i grabbed it...stupid me
Old Dec 12, 2008 | 08:07 AM
PainlessTexas's Avatar
FormerVendor
Default Melting fuse holder
It's basically this. You are running more amperage through the wire than it should normally handle. Sounds like you may have too high a rated fuse for the wire gauge. You need to look at all the components that are fed by the fused wire. What is the total amperage draw? You need to be sure your wire gauge and fuse are adequate to handle that draw. All electrical components will be labeled with their amp draw. Or at least it will be included in the instructions. But it's a good bet there is a label on each device showing amp draw. I couldn't find a quick and easy chart showing what wire gauge/fuse you need. PM me with the total amp draw and I'll get you the info. And YES..... It is important to check all grounds. They will also cause problems of all sorts.
Idryfly5
Sep 2, 2022 08:55 PM
dantheman1540
Feb 24, 2016 09:56 PM
treylittlefield
Jan 24, 2016 07:38 PM
Vortec350ss
Jan 12, 2016 10:36 PM
00loudchevy
Dec 3, 2015 05:54 PM
