MTX Jackhammers
Old Sep 15, 2011 | 09:39 AM
WICK3DxGATA's Avatar
Default MTX Jackhammers
okay guys im just wondering who has ever had the 10 or 12 inch jackhammers.
i use to hae 2 10s and i never had a single problem with them. but last summer i upgraded them to 12s in a mtx ported enclosure with a 1200 watt jackhammer series amp. but ive have had to warranty them out twice now because the sub farthest away from the port twice now the spider has started to separate from cone (or at least this is what i have been told, i am not the smartest when it comes to problems or interiors of a sub). so o was just wondering if anybody has had this problem with these subs in this enclousre also?
Old Sep 15, 2011 | 01:21 PM
Chevy_King1500's Avatar
then have a sealed box.
-bass will be cleaner
-box will be smaller
buy kickers
Old Sep 15, 2011 | 02:11 PM
08cheyennesc's Avatar
Buy JL AUDIO ,you will get bass that you can feel not just loud . The best sub I have had other than a 13W7 is the MTX 15" 9500.
Old Sep 15, 2011 | 02:42 PM
blueflamed03's Avatar
build a new box...problem is on that ported box, too much pressure is being applied to that one driver.
Sealed will lower output by alot.
Old Sep 15, 2011 | 03:17 PM
okay well i have an extended cab truck and want to build a new box form them that can go underneath my back seats the problem is that im not sure how much air space to give them or weather if i can port or not.
MTX says that they need 2 cubic feet or air space for ported and 1.25 for sealed. well i the biggest box i have found online for under the seat is one like 1.25 cubic feet per sub so i could do that if i wanted sealed. but i would like to stick with ported, i just have never seen a ported enclosure for underneath the seat like i would like to do.
Old Sep 15, 2011 | 03:51 PM
wow, underseat of xcab ported is kinda hard, you will need a custom builder for that. But you should have luck locally where your at.
Old Sep 15, 2011 | 11:36 PM
dmelvin's Avatar
You can custom port the boxes. You can use an online calculator to determine the port length, I did this with my boxes (they're different sizes, one is 1.63 cuft, the other is 1.28 cuft. I tuned them both for 30hz and it worked out just fine.
Old Sep 16, 2011 | 01:59 PM
I bet they sound different, same port frequency, but different sizes.
Old Oct 11, 2011 | 12:09 AM
Madewell 01's Avatar
Registered User
Check out the "pro bass pro" ported box. AMAZING sound loud and u can feel it. I was pushing one TEXAS BASS 12 with a brutis hyphonix amp in this box and it broke my db tester I placed 1st in a bass comp in my class. But everyone is partial to what they like and I am truly sold on thoes boxes.
mzoomora
Jan 3, 2016 07:06 AM
Ls3silverado
Jul 31, 2015 04:22 PM
Breitling
Jul 6, 2015 06:39 PM
Breitling
Jul 6, 2015 04:50 PM
