Pac rp5-gm11 problem
Old Dec 25, 2018 | 02:32 PM
BlownH2's Avatar
Default Pac rp5-gm11 problem
Hey guys, im having an issue with my 03 hummer aftermarket stereo. I currently am using a pioneer avh-201ex headunit, and a pac rp5-gm11 interface. Stock amp, and stock speakers. I had to remove the radio and unplug my interface to replace my yaw rate sensor, got everything back together, started the truck and the radio would turn on for about 3 seconds and then the screen would go black. The unit would turn completely off. Tried hitting the on/off button, no dice, checked the fuses, everything checked out, looked for grounding issues, none, and no loose connections, so i unplugged the interface and plugged it back in, the radio again turned on and then right back off. Im at a loss, and about ready to spend another 120 bucks on a new interface kit. Has any other gm guys have this issue? Or any pointers?
Old Jan 15, 2019 | 02:31 PM
Thetiderolls365's Avatar
Registered User
Check the harness for accessory when the radio is acting up. We run into this issue with the PAC harnesses, they lose the RAP circuit in the interface. If you run your own ignition to the Brown or orange under the steering column, i can almost guarantee your problems will go away.
A Low Dime
Aug 11, 2009 11:06 AM
SSlow 4.8
Oct 20, 2005 06:21 AM
RedRock_Z71
Sep 16, 2005 06:54 PM
styleandspeed
Feb 27, 2005 11:27 PM
stroked383z28
Jul 20, 2004 04:09 AM
