A little help...Rear passenger door speaker...
I don't know what happened but I have no sound from the rear passenger speaker. I have sound to front, rear, rear sub next to the 3rd row but for some reason none on passnger rear door. I just hear a click sound when i change radio stations or change songs on a cd. Not the clicking from a blown speaker (could it be that?) but like a click click...I removed the head unit and looked at all the wires/adapters and everything looks fine but when i gave a little tug i heard the speaker from the rear door pop and then the radio cut off and turned back on...did this several times when i was messing with it. I put the head unit back in and have soound to all speakers except that one....any ideas??? I appreciate it!!
probably blew the voice coil...or could be wires touching somewhere along the way too...if you have a voltage tester that is the best way to tell if the speaker is blown asside from the sound, lol
ahhh, i hate the speaker wiring stuff....I think it may be the speaker...How can I remove the door panel?? I saw a screw in the lower left corner but what else is holding it on? Clips? I unscrewed the screw and tried pulling up and out but something else is keeping it on. I didnt want to mess with it much at the time so I left it alone...
Also, on my head unit I have 3 sets of preamp outputs. I can just buy an amp and a sub and the rca cables go from h/u to amp and then just speaker wire to subs and that's it right? I havent hooked up amps and subs in a long time.
Thanks for your help guys!
RS/SS 4.8
Sep 17, 2015 09:17 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
