keep blowing Relays...............e-fans
Old Oct 21, 2006 | 10:23 AM
  #21
moregrip's Avatar
what a rush!
Originally Posted by bigredexpress99
or do as I'm gonna do when I build my harness.....use the relays out of the trucks and wire the fans in the exact way GM did for the trucks. No, there is not a connector available for the relays, but some crimp on ends and shrink wrap will clean it all up nicely. GM isnt having any problems with the fans......why are we?
you bring up a good point. I have often wondered if my 05 2500HD has the ability to control the factory efan harness setup, right down to the two pin activation from the wiring harness.
Old Oct 21, 2006 | 10:37 AM
  #22
bigredexpress99's Avatar
I'm about 90% sure it does. the pcm is no different. Hell, I might take it one step further, and see if there isnt a place I could put the 3 relays in my underhood fuse box, where they are form the factory, and pin it up there. Or see about getting that block from an 05+. this is gonna be fun..... I cant wait!! I love this stuff!!
Old Oct 21, 2006 | 10:38 AM
  #23
no different as pin inputs/outputs available, just programmed differently....
Old Oct 21, 2006 | 11:00 AM
  #24
moregrip's Avatar
what a rush!
exactly, in hp tuners it allows me to activate both.....
Old Oct 21, 2006 | 11:57 AM
  #25
Bill Reid's Avatar
Did you look through the McMaster-Carr catalog? Maybe something in there (?).
Bill
Old Oct 21, 2006 | 07:01 PM
  #26
white1's Avatar
You can find the relay harnesses on ebay. Id send you some but Im not home.
Old Oct 21, 2006 | 10:11 PM
  #27
the GM relays used for the trucks are an odd shape.....not a normal bosch type relay. Ive picked up about half a dozen relays and connectors from ebay for CHEAP and after seeing them and the wiring, decided to go a somewhat OEM way. I have a preliminary harness I just built a little bit ago......gonna give those a shot, as they are 40 amp GM relays and sealed connectors. Now I just have to dig up the two PCM pins I have........and get another liscense in EFIlive for the new truck.....there goes 99 bucks. That will probably happen later this week. Or tomorrow. Who knows.........
Old Oct 21, 2006 | 10:59 PM
  #28
moregrip's Avatar
what a rush!
cool, keep me updated
Old Oct 22, 2006 | 12:28 AM
  #29
I'll have pics tomorrow of the "so far" stage of completion. bed time.
Old Oct 22, 2006 | 01:34 AM
  #30
moregrip's Avatar
what a rush!
maybe I'll just go to a setup like this
