keep blowing Relays...............e-fans
#21
Originally Posted by bigredexpress99
or do as I'm gonna do when I build my harness.....use the relays out of the trucks and wire the fans in the exact way GM did for the trucks. No, there is not a connector available for the relays, but some crimp on ends and shrink wrap will clean it all up nicely. GM isnt having any problems with the fans......why are we?
#22
I'm about 90% sure it does. the pcm is no different. Hell, I might take it one step further, and see if there isnt a place I could put the 3 relays in my underhood fuse box, where they are form the factory, and pin it up there. Or see about getting that block from an 05+. this is gonna be fun.....
I cant wait!! I love this stuff!!
#24
no different as pin inputs/outputs available, just programmed differently....
#26
You can find the relay harnesses on ebay. Id send you some but Im not home.
#27
the GM relays used for the trucks are an odd shape.....not a normal bosch type relay. Ive picked up about half a dozen relays and connectors from ebay for CHEAP and after seeing them and the wiring, decided to go a somewhat OEM way. I have a preliminary harness I just built a little bit ago......gonna give those a shot, as they are 40 amp GM relays and sealed connectors. Now I just have to dig up the two PCM pins I have........and get another liscense in EFIlive for the new truck.....there goes 99 bucks. That will probably happen later this week. Or tomorrow. Who knows.........
#28
