How to disable 2004 escalade alarm?
Old May 17, 2016 | 05:35 PM
ZONES89RS's Avatar
In-Zane Moderator
Default How to disable 2004 escalade alarm?
Would like to ten the **** off and disable it. Some times it just comes on. Try to start it or even turn it off and it comes on. Over it and want to make it not work at all.
Old May 18, 2016 | 07:47 PM
BDR5oh's Avatar
cant .... its in the BCM .... sure its not aftermarket? .... ive never seen the factory alarms cause issues
Old May 19, 2016 | 10:31 AM
ZONES89RS's Avatar
In-Zane Moderator
Has no aftermarket that I know of. No way use some program to turn the **** off?
Old May 20, 2016 | 01:25 PM
BDR5oh's Avatar
do you factory key tags not work ? or you key cylinders in the doors not work ?
both of those will disable the alarm
Old May 20, 2016 | 09:05 PM
ZONES89RS's Avatar
In-Zane Moderator
The key has nothing. Just a metal key
Old May 20, 2016 | 09:39 PM
TXsilverado's Avatar
there may be a chip inside of the handle of the key.
Old May 21, 2016 | 06:45 AM
Phillip123's Avatar
There has to be a way
Old May 21, 2016 | 10:47 PM
ZONES89RS's Avatar
In-Zane Moderator
It is a solid metal key.
Old May 22, 2016 | 04:46 AM
Suburbazine's Avatar
You need to get a key fob or quit hitting the lock switch to lock the car. The lock switches arm the alarm, without a real GM key (plastic head) in the ignition you can trigger VATS as well. It's not that much money to get a working set.
Disabling the alarm is impossible without rendering wipers and locks inoperable as well. VATS can be tuned out but doesn't solve the crappy key problem.
Old May 24, 2016 | 04:37 AM
ZONES89RS's Avatar
In-Zane Moderator
Well, I'll see if tuning VATS out helps.
CooperS7777
Apr 1, 2017 01:12 AM
dantheman1540
Jun 5, 2016 12:23 AM
TrickTurbo
May 15, 2016 04:11 PM
BlueTexan24
31
May 9, 2016 07:48 PM
Lowexpo
Apr 28, 2016 11:19 AM
