Help with engine noise
Old Dec 2, 2005 | 02:12 AM
sikchevy's Avatar
Default Help with engine noise
i just re-did the system in the truck and now i have some killer engine noise and a loud clipping noise everytime i either change the radio station or insert a cd. any help with fixing this problem would be great.
Old Dec 2, 2005 | 08:57 AM
KySilverado's Avatar
I had some engine noise in mine. I turned down the gain on the amps and it took it out.
Old Dec 2, 2005 | 09:02 AM
thunder550's Avatar
High on diesel fumes
Check your amp grounds and also check to make sure that you ran power wire and RCA's down separate sides of the truck and cross them at 90 degree angles when necessary. Unless you don't have amps, then forget what I said
Old Dec 2, 2005 | 05:26 PM
sikchevy's Avatar
i will try turning down the gains and hopefully it helps. i have two amps and i will double check the grounds. any suggestions on the clipping noise?
Old Dec 2, 2005 | 06:08 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Grounds most likely. Do what Thunder said and your problems should be fixed.
black03rcsb
Sep 1, 2015 10:17 AM
superchomper2003
Aug 26, 2015 09:39 AM
V-seriesTech
Jul 28, 2015 12:31 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
