hard wire rador detector 09 chevy
Old Jan 29, 2009 | 05:01 AM
adamant118's Avatar
Registered User
Default hard wire rador detector 09 chevy
looking for ways to hard wire my detector so it comes on when i start the truck. any ideas?
Old Jan 29, 2009 | 06:42 AM
Coban's Avatar
Look for an accessories fuse in the fuse panel in the cab (if 09s have them). Then you can wire it in and have a protected circuit. Radar detectors have a very low draw so I wouldn't be afraid to put it on a circuit that was already used... Just not a vital one.
I used a fuse that was marked SEO ACC. This was in an 04 though. Your owner's manual should have some descriptions of the various protected circuits in the panel.
Old Jan 29, 2009 | 01:22 PM
53bowtie's Avatar
Grab a cig lighter extension and cut the male end off (the end you plug the radar detector into) and conect positive wire to a switched power source and the negative to ground. I generaly use the pink or orange wire in the ignition harness to do this and always use solder, never t-tap the ignition harness. I would also recommend putting a small fuse in the positive wire going tothe ignition wire, a 10A should be fine.
Thomas
Old Jan 31, 2009 | 06:55 PM
adamant118's Avatar
Registered User
looked at it today and i found NO key controlled power in the fuse panel to tap off of.
Old Jan 31, 2009 | 08:27 PM
swayoveride's Avatar
Try the invisicord (invisicord.com). It taps into the power on the rearview mirror.
Old Jan 31, 2009 | 10:08 PM
Wyttrash96's Avatar
I hate my cats
Not an answer to your question, but drool over this. This guy is my hero.
http://www.youtube.com/watch?v=JxRLyiBs3XA
Old Jan 31, 2009 | 10:14 PM
viciousknid's Avatar
Where's the Beef?
There is always something in the fusebox to tap into. nothing labeled ACC or radio?
Old Feb 1, 2009 | 11:21 AM
10RamSport's Avatar
Formerly 08_gmc_slt-08/20/2010
Best Buy sells a direct wire kit, they are in their Car Audio section right above the radar detectors.
Old Feb 1, 2009 | 11:31 AM
philntx's Avatar
Installed my Valentine using a short cord from Radio Shack. Modified the end with a short post. Inserted it into the mirror power connection.
Comes on when I start the truck.
Cost $4.00
Old Feb 1, 2009 | 06:00 PM
adamant118's Avatar
Registered User
thanks. just did it like the invisicord.com web sites states
ARC
57
Feb 21, 2022 10:54 AM
Zizzle
Oct 19, 2017 08:44 PM
Corvette454l88
Sep 1, 2016 01:24 AM
Fast86z
Aug 23, 2015 12:35 AM
Nimoryan
Jul 5, 2015 03:50 PM
