Escalade Gaugs Seem too dim?
I've had my Esky gauges in for about 20k miles now and the lights just seem to be getting dimmer. You can barely see that there on during a cloudy day and are not really too bright at night either. Any cure or remedy for this? I know LEDs would make it really bright but that makes you lose the dimmer function doesn't it? Now that I have a triple pillar pod set up they seem even dimmer than before.
Originally Posted by 02sierraz71_5.3
check the dimmer switch, Ive hit mine by accident
Maybe there is a slightly higher wattage bulb that would work in the cluster????
Check the voltage coming off the dimmer switch. I would suspect it before I would the cluster. Its basically a rheostat. Ov when off and 12v when wide open. Anything less than 12v at full bright check the incoming voltage. If its at 12v and cant get 12v off the other end your dimmer switch is bad.
dantheman1540
Feb 24, 2016 09:56 PM
