Disable auto dimmer rearview mirror.
Old Oct 14, 2005 | 03:00 PM
Default Disable auto dimmer rearview mirror.
Any one know how to disable the auto dimmer rear view mirror. it is on my 04" 1500 and it doesn't have onstar so there isn't a button to just turn it off like the manual says.
With the factory tint and a cap on the bed having more tinted glass it is always in night mode I can see out the back at all.
Old Oct 15, 2005 | 10:47 PM
so no one knows how to do this?
Old Oct 18, 2005 | 11:34 AM
Nick™'s Avatar
I figured it out once, but it shouldn't be in night mode unless the sensor on the dash says so, that's how mine is at least.... let me try to figure it out at lunch and I'll get back to ya
Old Oct 18, 2005 | 12:48 PM
BradS's Avatar
Just unplug it if you dont need it plugged in for Onstar.
Have you tried that?
Old Oct 20, 2005 | 09:41 PM
If I unplug it I will lose compass and temp too right! I don'e care if I need to cut the the sensor wire inside the mirror or what ever and I will have to do the same in the Escalade too I think.
Old Oct 21, 2005 | 01:29 AM
1badgmc's Avatar
My mirror in my 03 had a sensor up above the compass that turned the mimmer on when light was trans mitted on it. I hated it cause it was hard to use it with tinted windows. I finaly sold the truck, but not because of that..
Old Oct 21, 2005 | 09:47 AM
Yeah on mine it is built in to the mirror on the back side. I would quess that I have to take the mirror apart?
Old Oct 23, 2005 | 02:42 AM
Well I will be tearing it apart and making it work!
Old Nov 17, 2005 | 04:11 PM
Nick™'s Avatar
ok, I finally figured it out (been a while)....
if you have the compass/temp/auto dim mirror:
press and hold the temp button, watch the green indicator tight on the mirror housing (ignore what the screen does), when the green indicator goes off release the temp button, this takes about 20 seconds or so. now the auto dim will be turned off for all mirrors (regular rearview and if equipped driverside outside rearview)
SloSVO
Nov 22, 2020 07:34 PM
dsbodley
Nov 14, 2015 09:46 PM
Rockrz
Sep 29, 2015 09:07 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
