Escalade antenna location?
If you're trying to hide your antenna then it's pretty simple.
Unscrew the antenna from the base and then pull off the cowl cover.
Unbolt the 3 screws holding on the antenna base upright, reattach the antenna, and lay it down under the hood. Reattach cowl cover. Reception is just as good and now the antenna is hidden.
If you want more in depth instructions here's a link
http://www.fullsizechevy.com/forums/...s-antenna.html
