Door speaker change tips?
Old Dec 19, 2005 | 12:04 AM
SBChevrolet's Avatar
Default Door speaker change tips?
I got some Alpint Type R's to put in my doors I havent really looked at it but whats involved with pulling the door panel of? Also if anyone has any pictures of what the did to fit 5.25's in the ext cab that would be awsome
Old Dec 19, 2005 | 07:22 PM
KySilverado's Avatar
NBS door panels are removed by removing the door lock lever and removing the screw behind. Then remove the screw at the armrest. Pull off the plastic panel at the mirror and door handle then lift up on the on the panel. Then disconnect the electrics.
I just installed a set of Alpine Type S. They came with an adapter for the 5.25's. Lay down some dynamat then have to drill 4 holes to mount the adapter, the speakers then bolt into it. I removed the factory tweeter and put the alpine tweeter there. The crossover I mounted into the well at the bottom of the door.
Good luck.
Old Dec 19, 2005 | 08:27 PM
spitfire2332's Avatar
All I can say is take your time. I got in a hurry and half assed one of my speakers and now it rattles over every bump, and its like 5 degrees out so no way in hell im fixing it.
And then if u need to run new wires to the door run them through the gromet, wire harness thingy that the wires to PW/PL/PM goes to. I dunno how else you would run wires to a door but just a heads up i guess.
Old Dec 19, 2005 | 11:00 PM
blue 01's Avatar
Do a search you will find out how to remove the door panel. I don't remember if 03 are the same as 00 to 02 or 04 , 05. They are different between the two.
Here what I did to put 5 1/4 in the back.
link
Old Dec 20, 2005 | 04:24 PM
raIDERspeed's Avatar
I just did my system I put some Infinity Kappa Series speakers man they sound nice. MY system
Corvette454l88
Sep 1, 2016 01:24 AM
thewrx
Aug 12, 2015 08:28 PM
Ketis
Jul 23, 2015 12:37 PM
