big three ground questions
Old Feb 4, 2013 | 01:44 PM
JesseByrd's Avatar
Default big three ground questions
hey guys im looking for some insight on where the best place to run auxiliary grounds for my big three upgrade.i tried to find a post about it but couldn't( sorry if there is a thread about this already) my truck is a 1500 ext cab with the 5.3 in it and as far a the amp and wires i have 4 awg kicker wire going from the battery to the 600 watt (rms) amp mounted under the back seat and for now i have a cheapo section of 4 awg going from alt to the factory junction block. i now have a dual post battery so im going to run the amp and alt wire directly to the top positive terminal (using left over 4 awg kicker wire) or should i spend a bit to get 1/0awg
now on to the part i am not so clear on..finding the best ground location. the amp is grounded to the factory jack crank stud (the 14mm or one) and dont know if that is really the best spot but it worked for initial install. i also am not sure where the best place to augment the battery negative connection or bat. to engine block, block to body, frame to body or bat to body
Basically i am asking where you have your grounds run for the big three pics would be helpful or good descriptions
thanks
Old Feb 4, 2013 | 09:32 PM
jbancs's Avatar
I haven't done mine yet, but to answer your question, anywhere on the frame will work. I would drill my own hole sand the frame down to bare metal, and bolt it securely with a nut and bolt. Also, I would use 1/0. 4awg isn't that much larger than factory, just my $.02.
Old Feb 4, 2013 | 09:49 PM
dmelvin's Avatar
I used 2/0 wire because I had some lying around in the shop.
I ran Battery + to Alternator
Battery - to the bracket for the factory junction block.
Frame - to the other bolt on the factory junction block.
be sure when you do your frame ground you scratch off all of the frame coating where you're going to put your ground, it's some nasty stuff.
Old Feb 4, 2013 | 09:53 PM
JesseByrd's Avatar
i'm sure in the end that is what i will wind up doing, maybe not the 1/0 awg. looking at prices and its just not in my budget right now so i hope that 4 awg plus whats there should do on the ground side anyway. just trying to see what people have done and how well it works..thanks though
Old Feb 4, 2013 | 09:56 PM
JesseByrd's Avatar
dmelvin not quite sure what junction your talking about. are you saying where the power junction block mounts to the alt bracket ?
Old Feb 9, 2013 | 03:53 PM
dmelvin's Avatar
Correct. There are 2 bolts there for that bracket. I just used one for the - side of the battery and one for the frame.
I'll snap a picture of it for you if I get into the shop today.
Old Feb 9, 2013 | 04:41 PM
JesseByrd's Avatar
its funny i never really noticed those bolts till you said something about them, awesome thanks
USMCvet0311
Aug 1, 2015 07:45 AM
justuc
Jul 24, 2015 11:52 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
