Alarm with remote start install- PlEASE HeLP
Old Jan 26, 2013 | 09:23 AM
Db71's Avatar
Post Alarm with remote start install- PlEASE HeLP
It's been a long time since I've done an alarm install. I hav e anew one and want to put it on the gmc. The truck is man locks and windows so that will be easier. Anyone have the color codes/ wiring diagram? Ay issues I will run into?
Old Jan 28, 2013 | 01:16 PM
jbancs's Avatar
What year is the truck? The best place to look up diagrams if you're not an alarm dealer, is the12volt.com.
EDIT: just saw your profile. with a 2002 the install is cake because your BCM is behind the knee bolster and thats where pretty much all your connections need to be made.
Old Jan 28, 2013 | 07:44 PM
SSomeone's Avatar
Registered User
yea ive used the12volt.com for lots of wiring.. its a good resource.
Old Feb 13, 2013 | 10:26 PM
partyd's Avatar
Registered User
PART COLOR LOCATION
12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS
STARTER YELLOW (+) @ IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS
IGNITION 2 WHITE (+), SEE NOTE #2 @ IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) WHITE (-) @ BCM LT BLUE PLUG, PIN A5, SEE NOTE #3
PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH or BCM, LT BLUE PLUG, SEE NOTE #3
POWER LOCK LT. BLUE (TYPE A) @ BCM BROWN PLUG, SEE NOTE #3
POWER UNLOCK WHITE (TYPE A) @ BCM BROWN PLUG, SEE NOTE #3
DOOR TRIGGER SEE NOTE #5 @ BCM, SEE NOTE #3
DOMELIGHT SUPERVISION TAN (-) @ BCM, PURPLE PLUG, PIN B4, SEE NOTE #3
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLACK (-) @ BCM, BROWN PLUG, SEE NOTE #3
TACH WHITE (AC) @ ECM, SEE NOTE #4
WAIT TO START LIGHT DK. BLUE (-) @ INSTRUMENT CLUSTER
BRAKE WHITE (+) @ BRAKE PEDAL SWITCH
FACTORY ALARM DISARM LT. GREEN (-) IN DRIVERS KICK PANEL
ANTI-THEFT GM'S PASSLOCK 2 ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION SWITCH
EXTRA INFORMATION
NOTE #1: This vehicle uses GM'S PASSLOCK 2 ANTI-THEFT SYSTEM that requires a 791 Bypass Module to Remote Start, to order go to the SECURITY BYPASS MODULES Page on this website. NOTE #2: The IGNITION #2 wire WHITE must be connected to prevent a CHECK ENGINE LIGHT from turning on and to prevent DAMAGE to the TRANSMISSION on this Vehicle. NOTE #3; The BCM is located behind the Drivers Side of the dash, the plugs on the BCM face towards the rear of the vehicle. NOTE #4: The ECM is located NEAR the Battery, low, between the fender and the fan, under a BLACK PLASTIC Cover, on the 4.3L engine the tach wire is @ Pin 20, in the connector labled RED. On the 4.8L, 5.3L and 6.0L engines, the tach wire is @ Pin 10 of the RED Connector. NOTE #5: use TAN (-) for the Drivers door located in PURPLE PLUG, PIN B4, for the PASSENGER door use a ORANGE (-) in the PURPLE PLUG, PIN B2 or a DK BLUE/WHITE (-) in a LT BLUE PLUG, PIN B11, when connecting an alarm you must use both wires and diode isolate.
flatblack83
Jan 3, 2026 07:10 PM
murderedSS
27
Oct 12, 2015 11:13 AM
MA$TER_E
Sep 9, 2015 03:14 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
