Better alternator for 2006
Old Sep 9, 2008 | 09:57 PM
lpguy's Avatar
Default Better alternator for 2006
What are the options for hi output alternators for 2006 silverado owners?
Old Sep 9, 2008 | 10:26 PM
ces63ss's Avatar
get one from a escaled same year as yours so the connector is the same. I thinl you will have to go to a slightly larger belt. or you can take it to a shop and have them upgrade the internals to a high output.
Old Sep 10, 2008 | 09:21 AM
krambo's Avatar
DB Electrical will make any output alt you want (105 - 250 Amp) in any color that will be a direct bolt / plug in. After 150 amps, I would suggest upgrading the main alt to battery wire to 4awg with a fuse of the appropriate size.
If you want to really get silly, talk to Ohio Generator and have them build you a nasty 300+ amp with an external adjustable regulator. They also have custom brackets and such to run multiples.
Old Sep 10, 2008 | 06:46 PM
53bowtie's Avatar
cheapest route, and the route i took, is to have a local shop build one for you. I had a 200 amp made for me out of a 145 housing for $1 per amp. A little cheaper and you dont have to worry about shipping.
Old Sep 10, 2008 | 11:40 PM
matthimself's Avatar
rattron on gmfullsize....
Old Sep 15, 2008 | 10:17 PM
Bromaguire's Avatar
+1 on Ohio Generator I have one of there 250 alts. I've had it for about 4yrs now with no problems.
Old Sep 16, 2008 | 03:26 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
+2 on Ohio Generator worth the $$$
Old Sep 16, 2008 | 08:50 AM
blueflamed03's Avatar
Powermaster.
drummer0415
11
Oct 24, 2015 08:16 PM
BlownHD
Oct 3, 2015 12:24 PM
Cammed4ever
Sep 30, 2015 03:38 PM
bisqikss
Sep 27, 2015 09:40 PM
jtphelps289
Sep 1, 2015 08:58 PM
