anybody got cb radios?
Old Feb 18, 2008 | 09:07 PM
getchusum99's Avatar
Default anybody got cb radios?
just askin what brand do yall have and specs. im havin a lil problem getting a good signal with mine. i have a brand new cobra 29 ltd dale jr. edition and i have a wilson "lil will" antenna. i cant figure out why i cant get a good signal. i should atleast reach a few miles on the interstate.
Old Feb 18, 2008 | 09:24 PM
truckmann's Avatar
I gave up on CB's years ago and my knowledge is limited, but did you tune the antenna with and SWR meter?
Old Feb 19, 2008 | 01:53 PM
UnrthdxDream's Avatar
well first check your grounding. also make sure you don't have any shorts in your coax cable... if the antenna isn't grounded right it wont pick up/transmit far..
Old Feb 21, 2008 | 09:36 PM
i tuned my cb and antenna , and i checked all my wiring and it is good? what next?
Old Feb 22, 2008 | 02:02 AM
So you have an external swr meter to tune it with? where is the antenna mounted? roof i take it since its a mag mount.. I dont know what to tell you CB's are finnikey as hell and really irritate me. I had mine set up and was getting a swr of 1.5. I moved it over about 4 inches, same ground as before and swr is through the roof again. I really really just dont care about them anymore. If it works it works if it doesnt I cant tell you why lol. Probably time to pester the guys over at cbradiotalk.com they know alot although all they will probably tell you is to ground everything with flat braid ground straps. Like grount your doors and hood and **** to your cab and then re ground the cab to the frame. It seems like a waste of time to me but to each their own...
Old Feb 22, 2008 | 02:03 AM
Oh and did you use a multimeter to check for shorts tip to tip on the coax cable? Check the hot center wire and the outside ground jacket...
Old Feb 24, 2008 | 09:20 PM
no i didnt check that but i will. i have it grounded to the battery ,si that good enough? also i just used the swr meter on my cb . iguess i need to find a cb shop around here. thanks.
Old Feb 24, 2008 | 09:23 PM
truckmann's Avatar
I don't think it is the best idea to ground it directly to the battery. You really need to ground it to the frame or the body.
Old Feb 25, 2008 | 12:34 AM
I wasn't really even talking about the radio ground... I was talking about the antenna ground. I was upset the other day when i made that post cause my swr was high... well I went over my mount install and made sure to file off some more paint where the mount was grounded and boom! My swr is now sittin at 1.3 hahah.
Old Mar 3, 2008 | 05:10 PM
JakeBrakeIH's Avatar
I have a Magnum S6 and I love it...my only other suggestion to you other than what everyone has said is make sure that you dont have any extra coax "coiled up"...when I was 16 I had it like that and I couldnt get out at all and I brought it to a CB shop and he just laughed...meh thats what you get for being 16 right... lol...just thought Id put that out there
Corvette454l88
Sep 1, 2016 01:24 AM
drummer0415
11
Oct 24, 2015 08:16 PM
thunder550
Oct 8, 2015 04:53 PM
atxlt
Jul 20, 2015 11:06 PM
